stinkynathan
Setting up a computer for a friend here. Was having problems running both sticks of OCZ ram so I decided to flash the BIOS to see if it would fix it. Flashed using the windows flash tool that DFI has on their website using "update all" (if anyone is familiar with the program). It said it flashed OK so I rebooted. Now the BIOS will POST but instead of handing off to the OS it just reboots. It will do the POST, then reboot thing forever if I let it. It won't boot to anything.
I have reset everything to factory defaults hoping it would help but it didn't. What can I do here? I've never had a problem flashing all of the mobos that I've had until this one.
I've read that some mobos have a BIOS storage function (or was it multiple BIOSes?) where you can short some jumpers to copy it over or boot from the second one..... Does this mobo have that? I can't find any info on it.
nate
nate
