Help with Battlefield 2 and low FPS
Inferno69
20
Hello,
I have a decent system:
AMD 64 3500+
MSI K8N Neo 2 Platinum mobo
1gb (2x512 mb) ddr-400 ram
PNY 6800 GT Overclocked past ultra speeds w/ the 77.50 Forceware drivers.
Alright, what I'm trying to get at is that my Computer should be able to handle this game at maxed out settings, my friend has about the same specs and he can play this game flawlessly at high settings and aa @ 2x. When I put on the same settings I get looowww FPS, it's really annoying. Anybody have any suggestions? I closed down eveything in my bottom right hand corner before playing, i have about 38 processes when playing, no adware/spyware, no viruses/trojans.
Thanks
Inferno69
20
Originally posted by: BigfootsMonk
At the same resolutions?
I'd just lower your graphics settings and save yourself the hassle
Yes, the same res.
Originally posted by: Oyeve
Using Norton anti virus? That sucker is a game stopper!
Yes, I am :)
I can't close it in the processes thing because it says it's unable to or something like that.
kicks66
alll i do is disable it, not actually turn it off. i have a 6800gt with the demos drivers, i run everything on high except terrain, which is on medium. i also have view distance at 90% and the texture thing at medium and 2xaa, and i get perfectly smooth play.
nick
Ike0069
4,276
Try the drivers that came with the demo. They seem to help quite abit for nvidia cards.
Inferno69
20
It didn't work.
I tried the BF2 drivers and turing NAV off, both didn't work
I'm getting pretty mad, other people have a lot worse systems then me and are playing this game with maxed out settings at 4x aa
Inferno69
20
Originally posted by: Son of a N00b
Originally posted by: Inferno69
It's disabled...
http://img244.echo.cx/img244/487/processes0nv.jpg
no its not...
you can end all of these they are abbv.
hpotd
ctfmon
wdfmger
symcv
nv32
NPfmntr
ipodservice (YOU N00B CLOSE THINGS LIKE THAT)
spoolsv
firefox
CCEvmngr
SPB
SND
CCSET
itunes again (jeez! lol)
ccap
jusched
hope that helps! it should
the ones in bold give me this error:
http://images1.imagehigh.com/imagehigh/w/15062005170605_wtferror.jpg
I closed the other though, I'll try the game now.
Inferno69
20
it worked a tiny bit, you think that I might need to defrag my driver?
I've never done that and my computer seems to be loading a LOT when its in game
Ike0069
4,276
Have you ever installed the nVidia chipset drivers from nvidia's site?
If not, doing that will make a fairly significant difference.
Inferno69
20
whens the last time you reformatted your HD?? j/w...but this shouldnt effect game performance
About a month ago.
I'm pretty sure I did, not 100%.
S
SlitheryDee
Are you getting performance that is comparable to your friend's computer in games other than BF2?
Have you downloaded the latest patch, update, etc?
ASK THE COMMUNITY
