I'm a newbie to overclocking, but I have been searching through some old posts, but I still have some questions. First of all, unlocked means that you can change the multiplier - right? I can change the multiplier. I ordered a 2500+ on 09/24/2003 from newegg and I have been running it at the correct settings, but now I want some more speed.
I read that if I want to make it a 3200+, that I just need to change the fsb to 200 and possibly up the voltage. I set it at 11 x 200, and I moved the voltage up to 1.75, and windows xp would load up, but then it would freeze at my desktop, or the monitor would just turn off.
Right now I am running at 12.5 x 166 and it seems to be very stable. Asus Probe says my cpu temp is 42c and I think the bios says 44c.
My ram is 2 sticks of 512mb Kingston HyperX 2700. Should any ram settings be changed?
Anybody have any other ideas for me? I would really like to get this up to a 3200+. Thanks for the help!
