Heres the story...
a couple weeks ago I switched my case from a ordinary enlight case to a Thermaltake Xaser II Case A5000A Full Tower Case and I installed a swiftech MCX462 heat sink with a thermal take cool mod 2 as the heat sink fan on top. The computer ran pretty stably for about a week and then it started getting hotter for no reason. It got to 60 degrees C constantly and would reboot so i underclocked to a 1.2 ghz computer and it ran stably for a few days. Than one morning i tried turning on my computer and I smelled smoke and heard "system failed cpu test" from my bios' post.
I took apart the computer after that and looked at the cpu and rubbed it with alchol to clear up the artic silver 3 and it looked like it hadnt been burnt. I can't get it to boot up anymore with even the stock heatsink and I think that the processor is fried but im not completely sure, Im hoping my motherboard shtu off the computer before it fried since its supposed to. I might have it tested out soon at a local computer shop in Cedar Rapids. Im wondering that if it doesnt work, would i be able to use my amd warranty because I bought the retail version. I didnt overclock at all and Im pretty sure the heatsink was installed correctly, i spent a good 30 minutes to install just the heatsink. If I can get a exchange from amd, where should i contact them about it.
my specs
Asus a7v8x
Athlon xp 2000
2 x 256mb ddr pc2100 (kingston and corsair)
radeon 9500 pro
Antech 530watt true power supply
swiftech MCX462 w/ coolmod 2 fan
my specs
Asus a7v8x
Athlon xp 2000
radeon 9500 pro
