I have an unlocked Athlon XP 1900, with an Abit KR7A, and 256mb Crucial DDR. I have the multiplier at 12.5x and when I put the FSB to 136 I can run Prime95 fine, but RTCW freezes on startup. I have run the FSB up to 138 before with the multiplier at 12x. Is it my cpu, memory, or motherboard holding me back. Default voltage. I have very adequete cooling. A Thermalright AX-7 with a YS-Tech 48.5cfm, and 108cfm of movement in my case due to two 120mm Sunons. My case temps are 22c and my cpu is 39c idle. Full load case is 24c and cpu is 45c. Can someone please give me some help? Thanks in advance.
