- May 12, 2003
- 38
- 0
- 0
It won't work with the GART (AGP controller) driver installed. XP PRO SP1, ASUS P4C800-E DELUXE, 550w p/s, 2GB Corsair CMX512-3500C2. When I do a fresh install, instead of installing the AGP Controller driver XP installs the (also compatible) PCI Standard PCI-to-PCI bridge driver. That works, it boots and runs 3D, but about 40% slower and 3D Mark indicates it's not using AGP (AGP memory = 0). When I install the proper driver, it tries to boot but then goes blank right before the user logon screen before desktop. Everything was working PERFECTLY before I switched cards, my old one was essentially the same...an ASUS V9950 ULTRA TD (no video-in). It's supposed to be the same card except for the video-in. BTW, this new card I just got back from ASUS as I RMA'd my first TVD for the same reason, so I assume that it's been tested and is OK. I know if I call ASUS they'll say something like "Well, have you checked to see that your computer is pluged in?" so I hope somebody here can help me.
