- Apr 2, 2006
- 10
- 0
- 0
Hello all, new to the forums so treat me gently
Anyhow I have purchased a bunch of components to put together, notably the ASRock Dual Sata 939 AGP/PCIE mobo.
I need some clarification about the cabling from the PSU to the Motherboard. I have a Tagan TG480-U22 psu which has a number of leads including a 20pin connector plus a connector to make it 24pin (black) and a +12/P4 connector (blue).
Having set up the motherboard I put the 20 pin connector in the 20 pin slot and the +12/P4 in the 12v socket (as well as putting all the other connectors throughout the motherboard).
Horribly I smelt burning as soon as I switched it on and immediately switched off the machine. I took out the 12v power lead and the machine came on without the rear fans (the cpu fan was working as well as the front and graphics card).
Was I correct in where I put the 12v power lead (the blue one). If so, have I knackered the motherboard and/or cpu?
Any help appreciated.
