Help with another choice..
vikingblade
292
Another tough choice to make... with my last available $100 towards my new rig, im trying to decide whether i should go for a 7800GTX rather than a 7800GT or go for 2gigs of ram rather than 1gig. Which would affect my gaming performance the most.
Skyhanger
341
Look at your monitor size. At 1280 or less, the extra performance from the 7800GTX will not be as apparent. Thus your $ may be better spent on more system RAM.
Usually a GPU upgrade will improve performance more, unless you have not enough ram... what are your other specs?
vikingblade
292
Ive got a pretty decent..although crt monitor..big. viewsonic p225fb. i believe the rez goes pretty high...over 1600x1200, which is about where ill play i think. the rest of my planned system specs are...
athlon 64 3000 venice
epox 9npa ultra
seagate barracuda 7200.8 250gb
corsair value pc3200 1gig or 2 gigs
fortron 450 power supply
antec slk-3000 case
benQ 1640 dvd/rw
evga 7800gt co or 7800gtx
DaveSimmons
40,730
670
I'd probably improve the CPU for physics, AI, bots, etc. since you currently only have a 3000+ budgeted. But I run at stock, others here would say go for a massive overclock.
vikingblade
292
Thanks for the input. the upgrade to the gtx is so much more appealing than just another gig of ram etc...hehe. but, i understand what yas saying. alot of the newer games are really gonna need 2gigs huh??
how bout this spin on things... if i go with the ram option, what is the difference in value/performance on say...
1gig (2 512's) of higher quality, faster DDR500 PC4000 vs 2 gigs of value ram DDR400 - PC3200
Any idea on the performance differences
paulw86
419
simply put, A64 isn't bandwidth hungry, so faster ram wont give you much performance boost. 2gb of value ram will be better.
t3h l337 n3wb
2,698
2GB of value RAM >>>>>>>>>> 1GB of overclocking RAM any day. The performance increase isn't much at all if you get "performance" RAM, whereas the difference is pretty notiecable with 2GB vs 1GB.
