Help with an overheating video card
erythrophilia
I have a Visiontek ATI 4850 bought in 2008, and Antec P183 case with four 120mm fans (2 on the front, 2 on the back). I don't overclock anything here. At idle, Everest reported this:
GPU DispIO = 82C
GPU MemIO = 88C
GPU Shader = 90C
Whenever I started a 3D-heavy program (Kodu Game Lab in my case, or sometimes even watching Youtube), the temperature is like this:
GPU DispIO = 96C
GPU MemIO = 100-102C
GPU Shader = 100-102C
At this point, sometimes the computer just keeps running fine but most of other times, it will shut down automatically. I mean it'll shut down dead, and I have to unplug the power supply for it to reset (my PSU doesn't have an on/off switch).
I heard the 4850 can run really hot but is it normal to be this hot? Upgrade to a different cooler?
They do run hot, but not that hot. make sure the card fan/case fans are clean and free of dust.
If they are clean, you might need to reseat your video card heatsink and apply new thermal grease.
If that doesn't work, just buy another used 4850 for about 50$, don't spend money on a new cooler.
If you don't want another 4850 ,just save some cash for a gtx460 768mb and upgrade.
Many of those are single slot coolers with a shroud. They can get clogged with dust internally. Can of compressed air , a few squirts of air. You don't want to over spin the fan with the air, to much.
sounds similar to when a quadfired a pair of 5970's -- the only solution was to leave the case open and point a large desk-top fan directly at the cards. Not asthetic, but it works.
