- Feb 11, 2005
- 7,942
- 2
- 0
for some reason i keep getting this error message popping up when I'm in windows xp pro...I
"this action cannot be completed because the other program is busy. Choose 'switch to' to activate the busy program and correct the problem" and there's a box that says switch to, which just makes the start menu appear, a box that says retry, and one that says cancel that's greyed out. i'm not doing anything in particualr when it pops up, it comes up at different times.. but i notice if i go to my task list, IE is always listed, even though i don't use IE...so i'll shut it down, click retry, and i'll get an error message about scripts running on this page: http://www.oinadserve.com/code?pid=12&gid=16&rid=405130969&dom=12&dow=6&hod=0.
I've run adaware, and had no luck with finding any spyware...this is really getting annoying.
