Help with an easy form for logging jobs
Discussion in 'Programming' started by Fullhouz, Feb 5, 2013.
  1. Fullhouz
    Fullhouz Member
    Feb 6, 2001
    46
    First, I'm a dirt engineer, not a programmer. This is probably a stretch as a programming question but a little more than a shared spreadsheet. We've used a paper log form for 40 years and it seems there has got to be a better way using a database form/web app/google doc, maybe/some new tablet tool. The paper log book is used by 30 or so managers to log clerical jobs. When the clerical staff finishes a job, then they'll complete the log book entry. In simple terms, here is what the app needs to do:
    Located on the WAN, nonpublic; no security;
    simple table entry with 6 labeled columns, no wizards needed;
    entries need to include hyperlinks to .doc/.pdf on the network;
    open field entries shouldn't be necessary while using lookup tables for easy-of-use;
    each job is one row in the table;
    jobs only need to be kept for 3 days max;
    each day a new blank form is started and previous day's form is available;
    many concurrent users entering data;
    tool tips would be a plus;
    as another plus, would like to automatically email the requester when the clerical job is finished;
    So is there something out there off-the-shelf or do you have a suggestion for me?
    Thanks in advance.
  2. Loading...
    Similar Threads - easy form logging Forum Date
    What is the preffered way of checking if a form is submitted in php? Programming Apr 27, 2017
    How do I turn off the “NioEndPoint” Logging in Spring Boot? Programming Apr 21, 2017
    Web Form Length Question / Opinions Programming Jan 11, 2017
  3. EagleKeeper
    EagleKeeper Discussion Club Moderator<br>Elite Member
    Staff Member
    Oct 30, 2000
    42,600
    If the entries are not completely concurrent; then a spreadsheet on a shared drive will work.
    New worksheet for each day.
    User opens worksheet, updates and closes sheet
    Now if you want two users to be enter/updating at the same time; then you may need to go to a simple database type system.
    There are free SQL based databases and you just need a front end with some smarts for the users.
    The most difficult part is designing the front end form to make the end user comfortable/hand holding
  4. Fullhouz
    Fullhouz Member
    Feb 6, 2001
    46
    A dozen clerical folks will kept this form open all day so I think this kills the spreadsheet idea. So any suggestions on which database platform is the easiest to work with?
    Our IT department is exclusively using Oracle but I'd prefer to keep it simple with something stand-alone, if possible.
  5. Ken g6
    Ken g6 Programming Moderator, Elite Member
    Moderator
    Dec 11, 1999
    12,638
    292
    This sounds to me like a job for a bug or project tracker system. Free software for this kind of thing includes BugZilla and Trac - though Trac is strongly oriented toward software and the Subversion version control system. A lot of companies lately seem to prefer the commercial product Jira, which can be hosted on their site or your own.
  6. Markbnj
    Markbnj Elite Member <br>Moderator Emeritus
    Moderator
    Sep 16, 2005
    15,688
    8
    We use Bugzilla. It's functional but has an interface only its creator could love. Jira is very good, imo.
  7. Leros
    Leros Lifer
    Jul 11, 2004
    21,883
    Im a big fan of Jira.
  8. KB
    KB Diamond Member
    Nov 8, 1999
    4,648
    14
    A lot of people might say bad things about it, but Microsoft Access is a tool built for these situations. m ight be cheap to hire somebody to build it for you.
  9. EagleKeeper
    Staff Member
    Oct 30, 2000
    42,600
    Access had the problem that there was a database control file being created during updates by the program itself. Such precluded others from getting to the database in a write configuration. Ran into that back in '97.
    I do not know if it has been fixed.
    To use it as a back end with a simple interface program works well; I have implements multiple applications for small businesses that do not have the time/skills to use a large commercial program of setup something like Rally/Jira.
    Most times; the turn around for a prototype is within a week; the screens are simple and rules followed that were defined by the client. This way there is no real rework needed. They got what they asked for. :thumbsup:
  10. douglasb
    douglasb Diamond Member
    Apr 11, 2005
    3,163
    Google docs spreadsheet might work.
  11. BigDH01
    BigDH01 Golden Member
    Jul 8, 2005
    1,487
    4
    Is there a way to make opening a new tab the default behavior for clicking on a link in Jira?
  12. Munashiimaru
    Munashiimaru Junior Member
    Jan 14, 2013
    23
    Then 20 years later when it's become a monster that can not be satiated due to feature creep someone will be demanding to convert it to a real database.
  13. BigDH01
    Jul 8, 2005
    1,487
    4
    MS Access Sharepoint Edition.
