The 1075T is the most relevant CPU I think AMD sells right now. I run a X6 1055T paired with 1600Mhz ramm because 1600 speed allows me to OC to 3.8Ghz without crippling the divider. Future apps will get more and more multithreaded, so... I support the X6.
Getting the 880G or 890GX board is cool too. I am digging my MSI 890GX, very good quality + features.
The 470 is really an irrelevant card right now. Go for an OC'd 460 or the 6870 for the speed or the efficiency. I have my MSI cycle 460 at 850Mhz with no voltage change @ mid 40-50C temps while loaded.
The SSD is nice and should be in all current builds IMO, you can manage multiple games installed with 60Gbs but if you can afford reach for 80-120Gbs, ie Steam (TF2, Alien Swarm, Fall out NV), CoD4, HoN, ... etc.
Best of luck.
