Help with Albatron 845pev pro please with ati radeon
vietofmars
363
Something is seriously wrong with my board?
I have a 845pev pro loaded the 1.08 bios from albatron site
ati radeon 9700 pro
512 corsair pc3200 xms ram
1080 amg antex case with 430 true power
I haven't overclock my system yet my ram just arrived today and was just testing it at normal speed.
My computer loads up fine and the display is fine too but when I try to run 3dmark my computer freeze on the first test and I would have to reboot. In the bios screen I also switch everything back to default settings but the same problem stills occur. I know my ati radeon 9700 pro is not the problem because I was using it on my abit sr7-8x board and it works fine. I tired locking the agp/pci frequency and still it doesn't work?? Anyone suggestion what could be the problem and solution to fix ??
Thanks Ahead
Speedo68
58
I have a similar setup. OEM 9700 Pro, P4 2.4 @ 3.24(180*18), 512mb XMS3200LL. I have not run into any issues with 3dMark. You might try to flash the Bios to latest version and turning off fast agp writes...
