nboy22
i have a athlon xp 2000+, i just got 2 new case fans, and when i put the case fans in, the temperature only went down a few degrees farenheit. i'm wondering how I could get these wires out of the way cause i have a side fan that they are blocking, 2 fans on exhaust, (one on power supply, one on side of case) and two fans intake, (one at top, and one in back). 2 fans inside case to cool cpu and video card. so i need some suggestions on how to manage my wires, guides. etc.. feel free to give me some pictures of your case so i can see how you've aranged you wires.
Here is a picture of this disaster http://www.geocities.com/nboy222/DSCN1892.JPG
Now i want to get the temp down, it was running at about 140 farenheit, then i got these case fans, it's down to 130-134 farenheit, but i have a feeling that the side case fan has barely any impact on cooling, which like i said, the wires are blocking most of it's air flow ability.
I would also like to know what is the safest way to remove a little dust, as you can see i have a small dust problem on top of my vid card lol.. anyways.. thanks for the help, anything will be appreciated so i can get the temp down. 🙂
