Help with AIM + Wireless network
Matt2
4,762
I jsut set up another wireless network, this time for my dad and family.
Everything works fine. 3 computers and a laptop connected to the net via Linksys Wireless-B router (BEFWS11 or something like that)
All computers are up and browsing the net and they can see eachother.
AIM however is not working. When I try to connect it goes to "starting services", hangs for a bit and then says "Your buddy list is curretnly unavailable, please try again later."
WHats up with that? DO I need to open up a port in the router configuration?
LongN
402
my AIM always disconnects and I miss messages on my wireless, pisses me off
kly1222
AIM servers sometimes give that error message. Does the same thing happen when you switch back to your wired router?
Matt2
4,762
I just unplugged the router and hooked up directly and AIM works like a charm. The router must be blocking something that AIM needs.
The thing is though, I had AIM working for short times until that error message showed up.
I am leaving back to college and I refuse to leave my dad a shotty job. So please keep feeding me ideaS!
This is getting the best of me because my D-LINK setup at my APT doesnt have this problem with AIM.
Matt2
4,762
Putting a computer in the DMZ seems to have no effect. Still not working with AIM
oog
1,721
i don't have that problem with AIM through my wireless router (same linksys model as you mentioned, i think)
John
Moderator Emeritus<br>Elite Member
I've used a few BEFW11S4's and there is no need to open up any ports. Right now I have a D-Link 614+ and it also works fine. Just for kicks try the new version
Matt2
4,762
well what the heck is going on!?
I spent an hour with the linksys tech and he had me open about 9000 ports, it finally logged on, he bounced and then a couple minutes later it did the same thing!
onlyCOpunk
2,532
Try upgrading to the latest firmware if you haven't already. That's all the advice I have. I used that same router for a while and everything worked fine for me.
