help with a simple regular expression
lockmac
603
Hi guys. I am having trouble grasping regular expression (like many im guessing).
Anyways, I need a regular expression that will accept the following.
A number between 0 and 100 and .5 values are acceptable.
Eg. 40.5 is acceptable but 40.4 or 40.7 is not acceptable.
Thanks very much
slugg
4,723
80
let x = the number...
if(2 * x - (int)(2 * x) || x < 0 || x > 100)
number is bad
else
number is good
lockmac
603
thanks for that mate, but i cant use code for it, it has to be regular expression (this is to be used in an xml schema declaration
Snapster
3,916
Try
^\d{1,3}(\.[05])?$
matches 1 to 3 decimal numbers at the start and if any decimal point it expects it to be a 0 or a 1, hopefully!
presidentender
1,166
40.5 is okay. Is 40.0? What about 40?
Regular expressions work on Strings, so this is an important distinction. Assuming you want 40.0 and 0.0 and 100.0, not 40:
([1-9]?[0-9]([.0]|[.5]))|([100.0])|([0.0])
should work. I didn't test it. Check this out.
lockmac
603
Hey snapster- that worked a treat, except that it accepts values over 100, which is okay i guess, i can write some different logic to deal with that.
presidentender, 40 is okay, 40.0 is okay, but 40.4 isnt. Im basically wanting a full number (can have the decimal .0 put their if they want) but it can only increment in halves. Its for a student mark file and half marks are acceptable. and thanks for your string, but it didnt seem to work at all :(
Snapster
3,916
Ah yeh, forgot to test over 100 :)
Try this:
^(([0-9]|[0-9][0-9])(\.[05])?|(100)(\.[0])?)$
It should allow 100 and 100.0 but not 100.5 too.
