Help with a fan replacement for AIW 9000
Can anyone point me to a replacement fan, or a good site to purchase from? I checked newegg and as far as I can tell, they don't have a replacement that will fit. I found a site via google saying a Vantec Iceberg 4 would fit, but couldnt find dimensions.
I haven't ever bought a GPU fan or heatsink, and want to make sure I get one that fits. My vid card is an ATI AIW 9000 64mb AGP card. The fan itself is 45mm x 45mm x10mm high. There is not any extra room to top left of fan, so I think i need an exact fit.
Any suggestions on fans or reputable dealers would be appreciated. Sorry if I asked a common question, didn't see any similar questions by searching.
Thanks
Ryan
Thanks for the suggestion. I see the BFG fan is listed as a generic, but I couldn't find any specifications on the size or what models it will work on.
If my fan is 45mm x 45mm x10mm high is it a 45mm fan, or is a 60mm since is is 60mm corner to opposite corner?
Thanks again
I remember that BFG unit being closer to 60mmx60mm, but I gave that card to a friend a while back so unfortunately I can't measure it for you. Almost sounds like you may be better off finding a larger Passive chipset cooler and mounting a case fan so it blows over it.... Or perhaps look into a Chipset HS/F as those will be the smaller ones.
Here's all the 45x45mm fans on newegg.... All 2 of them
http://www.newegg.com/Product/ProductLi...xPrice=&SubCategory=62&Submit=Property
