help with a duron 700 and an a7v133
Zipperhead
1,277
i bought a duron 700 that is supposed to run at a gig.i am using an a7v133 with rev2,and an alpha hsf with silver grease.i have tried many
different settings,the highest it will post at is 800-thats a long way from a gig.is there anything i am missing?i tried 7.5,8,8.5,9,10 by 100
fsb.i also lowered the multiplier way down and raised the fsb to see if maybe it was something else in the system,everything else seemed good.thanks. using bios 1001
Bartman39
Elite Member | For Sale/Trade
Jul 4, 2000
8,867
51
That bios 1001 might be the problem I would flash to the newest (either 1003 or 1003a) also what voltage are you doing this at??? Sometimes a lower voltage will help a lot (mucho less heat generated).
The Rock
Do try the latest bios it might help but a sure bet would be to go into "jumper" mode and O.C. your Duron that way. I have 750 Duron @800(6x133) core voltage 1.65 and everything is running fast and stable! Good Luck!
