help with 9600 pro and FPD2185W
im trying to install the latest catalyst drivers so i can play the prey demo due to the fact that the windows drivers for my 9600 pro have some odd open gl glitch... so then i installed them (using the drive cleaner to make sure i got rid of the previous ones) and then after i installed them, i reboot and it's 640X480 at 16colors and i cannot change it... and i think its the monitor, yet i'm not sure... due to the fact that its a widescreen monitor thhat doesnt include drivers (so it defaults to plug and play) and the catalyst cant support it but the microsoft ones do...
thoughts? fixes? etc?
all i want to do is play the Prey demo on my PC cause they havent released it on XBOX LIVE yet... 🙁
Sounds like you didn't install the drivers correctly
i have installed them 6 ways to sunday according to every tutorial known to man... what could i be doing wrong???
ive basically given up at this point unless someon ecan help meout, maybe yet ANOTHER tutorial?
Do you get the Catalyst control center?
same results... had to use a system restore point to get the microsoft drivers that work back...
even the CCC told me to update my ATi drivers... :\
Looks like the new drivers are not installing for you. You talked of using "driver cleaner". Did you go to "Add/Remove programs" and remove the ATI control panel first and then the ATI drivers? Have you tried downloading the drivers again just in case the first download was corrupted? The 640x480 at 16 color is a sure sign that you are running on basic video drivers and not the ATI drivers.
I guess I may next move would be to make sure there are no signs of anything about the ATI drivers or control panel in the "Add/Remove Programs" area. If there is remove the ATI stuff from there first. Go here http://www.drivercleaner.net/ and download the pro version (free). Read and follow the direction for this program. Do not run the drive uninstall from regular Windows. This will clean out any trapped or left over ATI driver files in your system. After rebooting, you will be back at the 640x480@16 color display. Now run the ATI driver install and the ATI Control Panel install. Make sure the drivers are for your operating system and the 9600 pro card before installing.
Last, if you still have problem you can try the fourm board over at http://www.rage3d.com/ as that site is all about ATI stuff. I have an ATI 9600XT and have not had this problem like you are having. I have had problems something like this with on board sound and XP trying to install drivers that XP thinks it should. Do not let XP install anything with the video when you reboot. Get to the desktop with the basic 640x480x16 drivers and then run the ATI install. The only way to get the sound problem I had fixed was to the program from the above site and keeping XP from installing anything when I rebooted the system. That let me install the proper drivers.
i've done all that! thats what i've been doing! i've even booted into safemode to use driver cleaner to make sure i got everything after i used control panel to uninstall any remnants of ATi software! hell, when my PC just calls my video card "Video Controller" in the device manager i get 1280X1024.. after I install the ATi Drivers, then I reboot into 640X480 in 16 colors....
this is becoming rediculous, i'm going to head over to rage and see what they can do...
thanks anyway guys, it's been a pleasure
