I have some 8mm 112mm tapes that are used in a Exabyte 8205. I do belieave this drive does about 2.5gigs/5.0gigs compressed on one of these tapes. The Exabyte 8505 supposidly uses the same 112 8mm tapes and can do 5gig/10gig compressed off this same tape?? Is this a mistake or would the Exabyte 8505 only be able to fit 2.5gig/5gig on one of these 112 tapes?
Also..
The reason I ask is I might be upgrading my Tape Backup with a differnt cheaper drive and need to know if getting differnt higher capacity drive will work with the current tapes I have. I'd hate to get rid of 20+ brand new 112mm tapes that I have and would perhaps think about getting the same drive if I can't.
Any recommendations of a Tape drive that uses 112 to their max if its more than 2.5gig would be helpful too.
Also..
