Help with 2.6 Celeorn CPU
PANDI2005
Hello,
I have recently assembled a system. The hardware Monitor from SOYO shows CPU temp at 45C idle; Chaisis at
C.
I am perplexed at what chould the system run at ?
Is it safe to be running this high ?
Any and All Input/Advice is greatly appreciated.
Thanks In Anticipation
Here are the system Details
Processor : Intel Celeron 2.6Ghz (Socket 478)
MB: Soyo SY P4VGA
300 W Power Supply In ATX tower.
Memory: 512 SDR-133
2 IDE Drives Western Digital
1 DVD, 1 CDRW
Xtasy Video MX420 64Mb
NIC -100 Mbit
Internal Modem
Fan For Cooling CPU: Speeze P4 (478) Cooling Fan up to 3.0 GHz (used the stock white grease for attaching to CPU)
Fan Description at : http://www.tigerdirect.com/applicat...ails.asp?EdpNo=315503&Sku=S457-1003&CatId=795
Case Fans:
2 * 80 mm For Exhaust
1 PCI Clot Fan For Exhaust
1 80 mm For Intake
1 80 mm just for directing some more Air at The CPU & FAN Assembly
All 80 mm are Speeze fans about 30 CFM. here is the
Specifications:
Bearing Type: Sleeve
Nominal Speed(RPM): 2500+/-10%
Max Air FlowCFM): 31.73
Rated Voltage: 12V DC
Connector: 3+4 Pin
Noise(dBA): 28.0
First, dont trust hardware monitors on the mb BIOS. Get MBMonitor5 instead and configure the sensors for your mb: http://mbm.livewiredev.com/
45c is high but not dangerous. Is it one of those compact Soyo cases with the PS hovering right over the CPU? You may want to add some case fans.
Did you buy everything at Tigerdirect, or just the fan? Just wondering. I hope you're not waiting for a rebate.
You should be fine, but you need to find out what it runs while using 100% of the processor's power. The Prime95 torture test is great for that, as are a few other things. As long as you keep the cpu temp below ~60-65C, you will be alright.
