Ok, this may make me look really stupid... but I don't care.
I have an Athlon XP 1700+ with a Thermaltake Volcano 6cu+ and I wasn't satisfied with the temps (~50 C full load).
So, I got a 80mm fan from an old PS and tried to splice it into one of the cables running from the Power Supply in my PC. I thought Red (+) and Black (-), no problem. The particular cable I used was also connected to my HD (eeek, I know!). I spliced it in and started it up just to see if it would work before I taped up the connections... I tried to make sure the 2 bare connections (positive and neg.) didnt touch, but when I tilted the case to make an adjustment to the fan they must have TOUCHED!? I have no idea really what happened but my PC shut down on its own and then when I restarted smoke started rolling out of my HD!!!
Anyone know what happened? Or at least can someone tell me the proper way to hook up a fan without pins?? Thanks.
