I recently reformatted my Dell Latitude D800 laptop. If memory serves me correctly, my speeds after the reformat were normal (around 600kb/sec). I don't really know what happened but suddenly, my laptop can only achieve up to 300kb/sec max! My desktop across the house, downstairs that is equipped with a wireless USB adapter is averaging about 450kb/sec. Mind you, the signal strength for that computer is "Weak" because of its far distance.
At first, I thought it was Internet Explorer acting up but I downloaded Mozilla and I achieved the same speeds.
If I were to unplug the Cat5 cable from my laptop and use the built-in Wireless, I would STILL get the same speeds. It seems like something in my computer is maxing out at 300kb/sec.
Here are my DrTCP settings:
TCP Receive Window: 65535
Window Scaling: No
Time Stamping: No
Selective Acks: Yes
Path MTU Discovery: Yes
Black Hole Detection: No
Max. Duplicate Acks: 2
TTL: 32
Dialup RAS MTU: Blank
MTU: 1500 (set for both my built in NIC and the built in wireless)
Here's something that is odd. I already tried removing and re-installing my built in NIC and the built in Wireless ("Broadcom 570x Gigabit Intergrated Controller" and "Dell Truemobile 1300 WLAN Mini-PCI Card") and that didn't work. However, under "Adapter Settings" in DrTCP, it shows 2 instances of both adapters. Perhaps I improperly re-installed these 2 adapters?
Last but not least, here is my Tweak Test results:
http://ttester.broadbandreports.com/tweak/block:380558b?service=cable&speed=5000&os=winXP&via=normal
Thanks in advance!
Window Scaling: No
Time Stamping: No
Selective Acks: Yes
TTL: 32
Thanks in advance!
