Basilisk
A long-running household computer won't boot: something on the disk became corrupted, although the last shut-down was uneventful. I swapped *all* hardware save the disks, IDE cable and power cord. [Yes EVERYTHING, m/b, proc', etc.] Regardless of the parts, it crashes in exactly the same manner: it looks like a fine boot until it throws some noise on the monitor and self-reboots just before it should be putting up the login page.
Can't boot to admin/diagnostics level -- same failure. Logging doesn't show anything strange. Telling it to use the previous successful version doesn't work.
All I can think to do are (1) boot from CD and look for some restore[?] option, or (2) put the disks on another XP pro computer and run diagnostics there.
(1) Of course, I can't find where I left my @#$%^ iridescent master XP pro disk. 'Have looked throughout my house and my girlfriend's where I've used it -- surprisingly even with legitimate PKeys! 🙂 Even if I found it, it was SP1 at best. 'Can't find a torrent of XP pro SP2 English -- one's listed, but withdrawn. I -do- have my master copy of XP *home* SP2... but I doubt that would be sane or even work on the Pro system.
(2) Other than doing a disk-check, I'm unsure what I can usefully do with the system's disks mounted on another XP pro system. 'Guess I'll do that, but I was wondering if there's a better Plan.
Thanks for any insights on this!
Edit: Since the above, I've put the HD in a working system and run diagnostics on the disk. Nothing was gained by this.
