Howdy,
This problem has come up regarding a Compaq Presario 1200 Notebook and upgrading from Windows ME (original installation) to having XP Pro put on, to now having XP Home (with SP2) installed. The computer was never formatted, so it was never a fresh clean install.
Originally it had Windows ME, but XP Pro was added over top of the OS, so you could choose to either go into Windows ME, or XP Pro (and it has a timer that counts down from 30 seconds).
XP Pro wouldn't work after MS Publisher was loaded onto the system, and the XP Pro disc was not working as it was a developer's edition, and not a bootable CD.
The notebook was taken in to a local computer shop, and XP Home was purchased and installed (that is what they said was the only way to fix the problem) because it wouldn't load Windows XP Pro.
Well, now there are three options at the boot screen: a. "Windows XP Home", b. "Windows XP Pro", and c. "previous OS"
Choosing the last option an error message appears when Millenium tries to load up, with the message that VMM.SYS (or something close to that) is missing.
Choosing the XP Pro option goes back into the XP Pro installation screen, but now the serial number is not accepted what so ever. Could The XP Home installation have done something?
Now the XP Home software works, but there are duplicate files, users, and other things, and sometimes triplicate files as well.
What is the best solution for this issue? Any ideas on how to fix the problems? The MS Office suite has issues to whenever any program is run it searches for files, and eventually loads up.
Is the best thing to just do a clean wipe, and start from scratch? Can anyone explain what has happened to this system with so many OS's overlapping?
Thank you for any and all of your help, it is much appreciated.
