Help Windows 64 Install UPDATED! Need Help???
jrphoenix
1,295
Hello,
I have had my "free" copy of Windows 64 sitting around for a couple months and finally have decided to install it. I have some problems now??? I have 2 hard drives, a seagate 7200.7 200 Gb and I just bought a seagate 7200.8 250 Gb for the new OS. I unplugged my 7200.7 (both drives sata) and proceeded with new windows install.
Formatted drive
Installed OS (initial blue screen)
Windows reboots and then gives me "error loading OS"... I have to go back to boot from CD and start over???????
Anyone know what would cause this.
Problem 2... On my Windows XP Pro I use Norton Internet Security 2005. Will this work with the Windows 64 OS??? If not I may use the free Windows firewall or does anyone have suggestions for free antivirus / software firewall for Windows 64?
I can also use the Nvidia firewall for free on my NF3-250 mobo.
Thank you!!!
EDIT
Ok... I left both hard drive plugged in and I select to intall the new OS on the 250 Gb 7200.8 Seagate (the old 7200.7 200 Gb drive has my XP Pro 32 on it. When I install now and reboot I get this error:
Windows could not install because the following file is missing or corrupt:
<Windows Root>\system32\ntoskrnl.exe
What do I do now??? How to I get XP 64 to fix this error on reboot after installing to a new formatted HD?
Also... the 2 hard drives are show at bootup on a reboot (one with xp & one with xp64). The system has the xp64 highlighted by default and gives 0 seconds to select? How do I change how long I get to select a HD and how do I make XP 32 the default selected (for my wife)?
Thank you!!!!
jrphoenix
1,295
Thank you for the info schadenfroh (good writeup).... Any ideas from anyone on why XP64 won't load?????? Ughh.
jrphoenix
1,295
Originally posted by: sandorski
If by Free you mean a beta version, it might be Time expired.
Hey Sandorski... not the beta. MS gave purchasers a period of time to turn in their XP Pro license and pay shipping & handling ($12) for the XP 64 version. It won't install though?
Anyone have this problem?
