help.. win2k freezes when overclocking.. ayhja OCers what are your specs?
SinNisTeR
3,570
what can i do to prevent this? i keep getting a blue screen with some stop error.. it says something about IRQL... where exactly in the bios is the pci divider? also should i overclock using the fsb more or multiplier?
edit: ayhja 1.4 ocers.. what are your settings for the cpu?
FSB:
Multiplier:
Vcore:
OS:
ram voltage:
etc..
DimZiE
1,093
install service packs..disable ACPI (try to find this in your BIOS settings)
this helps my w2k freezos
what is your mobo anyway
SinNisTeR
3,570
i should have clarified... when i OC i can boot into windows with the new settings..
im using the 8k7a+ with 1.4 ayhja, i can post and start booting at 1680 and i get windows error :(
DimZiE
1,093
yes i know that.. try my suggestions anyway..
since W2K assigns all your PCI devices on the same IRQ (IRQ11)
and you've stated that the error
<< .. it says something about IRQL... >>
someone on this forums suggested me to install SP's and disable ACPI it works for me...
considering o/c ing:
if you want to reach high clocks:multiplier
faster overall performance:FSB
hope this helps
DimZiE
1,093
wow yeah almost forgot about heat....(waytoomuchcoffe just snap me back to reality)
what r your temps..what HSF n' thermal interface r u using..
this could be the main thing that's causing you probs n' i have stupidly forgot it altogether
waytoomuchcoffee
433
11
btw, the IRQL error doesn't have to do with assigned IRQ's. This happens when a kernel mode process or driver attempts to access a memory address that it doesn't have access to. It's usually a driver issue, but when overclocking, kernal process errors (i.e. the guts of windows) are pretty common.
I have to say, 1680 is damn high. You usually only get that with watercooling. Anything in the high 1600's with air cooling is pretty rare, and if you are using air cooling your case probably sounds like a few vacuum cleaners. I assume you are using a Black label fan for this monster o/c?
You o/c by changing the multiplier first, then tweak the FSB. See how fast you go, then drop the multiplier down by .5 and see how far you can up the FSB. See which one is better (in actual benchmarks). Multiplier won't screw up your system cards or memory, but increasing FSB speeds up everything. A 1600 o/c with FSB will run faster overall than a 1600 you got from just multiplier o/cing. But you might have better benchmarks at say 1550 with FSB oc/ing than a 1600 you got with straight multipliers.
What is your fastest STABLE o/c? I mean by running stuff like Prime95 or 3dmark2001 at demo with high resolution for a few hours?
SinNisTeR
3,570
hehe.. i should take some pics..
i did a case mod with 3 120mm delta fans @130 cfm right on top of the cpu and vid.
im using a alpha 6035 with a 30cfm 60mm fan on it. the lowest ive seen at default was 38 C. 42 at full load. (when its cold.)
when its hot its 43 - 47 C.
when OCing at 1680 cold its 43. but this is at default everything, the only thing i change is the FSB.
air cooling your case probably sounds like a few vacuum cleaners LMAO, no comment..
if i can boot into windows id be set..
i tried the ACPI.. nothing yet, i tried raising the voltage and comp restarts at the dos win2k bootup window.
its at 10.5 mult. and i changed it to 11 and it keeps going coo coo. i want to find exactly where in the bios that im supposed to enter in the 1/5th pci divider so that i dont get 45mhz on my SC and NIC, lol.
SinNisTeR
3,570
the ACPI disabled was causing me to freeze. humm weird.
edit: talk about low 5v rails.. sheesh.. whats the lowest you guys have seen? ive seen myself at 4.58 on the enermax 431
heffe734
2,304
just because it boots does not mean that it is stable...if you're getting errors in windows...that means you need to back down your OC.
heffe734
2,304
lol....try lowering your multiplier a lil...sinister...also run prime95 if you do boot up into windows...that way, you'll know for sure whether you have a solid stable speed.
phatstyl
1,530
it is a know problem that your mobo and enermax psu's dont play nice. Im sorry to say i know of no remedies
