Imagine the exitment: I just put together a high-end machine (for gaming mostly) last week. everyone advice on using Win Xp (why not?).
You won't belive that it has restarted and frozen over 50 times in three day. The first two times where during installating (on a clean system
Specs are:
AMD xp 2200
Ausu A7V333
Samsung DDR333 512Mb
ASUS GF 4600 Delux
2 x WD 80GB (NOT in raid) 7200
1 x Quantum 30GB (mobile Rack) 7200
Plextor 40/12/40
Pioneer DVD-CDrom 16/40 (which is currently disconected in order to connect the Quantum)
(So you can't realy complain about recurces)
Software
Win Xp Pro (no SP installed)
Nvidia 40.41
Latest ASUS Bios-update
Extras:
Sant Cruz TB (latest driver)
B2C2 Broadban Reciver PCI Card
Ir-port device connected to COM1 (for mobile phone conectivity)
USB keyboard (logitech navigator)
USB mouse (logitech dual optical)
When it works it works fine (3dMark 2001 ~12500 points)
But very often it halts on error (for instance: while I was writing this post, it closed the other explorer window due to unkown-error DAMN, and it was just open with Anand home page and it was idle, WTF) and other times it freezes completly and I have to reset and other times it just restarts on its own. Very annoying. Some times, if i don't do any thing then nothing happens, but when I play a game (Warcraft3 or SOF2) it always restarts after like 20mins. ito the game.
When I copy large files (DVD-rip) from one harddisk to another it also freezes very often.
There are no harware conflicts, no viruses. I just dont get it.
Please help if you can. Some one adviced me to do the following: Clean install, with just the most nececary components installed in the PC (mobo, GF, one hard drive, cd-rom, monitor) and then, when XP is up then to start installing the components one by one and waiting 2 hours between each to find out what is causing the problem. This would be a long a frostrating project. So if you have any other suggestion please post.
First I tought it was just the raid, so I dis-enabled it from the modo. (I could not copy amy file bigger the 1mb from raid to stock hard drive). No no All 3 hard drives are on stock IDE and I diconected one of the cd-roms.
I am ready to clean install, but I just want to know what could be the problem, cause I don't think it will be solved.
I know it has to be something with my machine cause even WIn98 does not freez this much
HHHELLPPP!
Specs are:
AMD xp 2200
Ausu A7V333
ASUS GF 4600 Delux
Plextor 40/12/40
Software
Nvidia 40.41
Extras:
HHHELLPPP!
