eternalpeace
I am having a bunch of problems installing win 2k pro.
Here is my system: (everything is brand new)
2.4C (stock hsf; arctic silver 3)
Abit IS7-e
2 x 256 Corsair XMS 3200C2 (initially recognized as 2.5-3-3-8)
Maxtor 80gb 7200rpm
Here is my problem:
Plug everything in, boot it up - no problems.
I partition all 80gb to FAT32 using maxtor's utility.
Just before the copy file stage of win 2k setup, I get a message that says my bios isn't ACPI compatible. I reboot and it never gives me that message ever again.
Second time in the copy file stage keeps giving me copying errors
e.g. xxxx.xxx cannot be copied....
I reboot, same problem at the same place but with different files.
I take out one of my memory modules so now I have 1 x 256, go into bios and notice that the cpu temp is at 51C (open case) and the memory timings are now at 2-3-3-7. I clear the cmos, reload bios defaults, and the timings are STILL at 2-3-3-7, everything seems to work correctly, so I forget about it and move on.
I repartition only 5GB of the HD with FAT32
This time, (1 x 256) everything copies correctly, and I get to boot into windows for the first time... I get a physical memory dump, (didn't note the hex numbers)
Reboot, going into windows.... another physical memory dump.
Reboot, going into windows.... no physical memory dump, but says a file is corrupt
Reboot, going into windows.... no memory dump, but says ANOTHER file is corrupt.
I give up and go to bed.
What is the problem here? I know IS7 has issues with PC3200 memory, could that be it? Do I need a newer version of my bios? Or do I just have a really ghetto copy of windows? Should I try NTFS? I would like to do a little gaming, would NTFS get in the way?
All help is MUCH appreciated.
Abit IS7-e
Maxtor 80gb 7200rpm
Here is my problem:
