HELP!!! Will this slotket work with my cpu and mb???
kly1222
Okay, here's my situation. I just got an Asus S370-L rev. 1.00 ppga to slot 1 converter. I noticed that the documentation says that the lowest voltage it can be set to is 1.8v, and it works for 66/100mhz bus cpu's.
Will this thing work with a 700e o/d'ed to 933 (1.65v w/ 133mhz bus) on an Asus P3B-F? Or am I SOL? Please help.....
I don't think you are supposed to put an FC-PGA P3 or Cele II in a PPGA socket even though they may fit - whether that socket is on a mobo or a slocket.
Be sure you have a slocket that is for a P3 !!!
I can't tell from their web site whether that card is for PPGA or FC-PGA.
It should be a ppga slotket. So fc-pga cpu's don't work in ppga sockets? Damn intel....well, off the e-gay it goes....
