HELP!! Where is the best place to buy: Motherboard + CPU upgrade kit? Thnaks for your help
Maxfly
92
Where is the best place I can get a motherboard + CPU upgrade kit. I need a p3 500...I don't want to mess with jumpers, etc so I wanna buy it already tested and with the jumpers set. I appreciate your help.
Looking for the best value.
THANK YOU
CombatChuk
2,008
This might not be what you're looking for, but I find it easier just to look for the MB and CPU seperately on pricewatch. It's just me, but I think it's cheaper to just do it yourself.
novice
1,169
I bought a barebones system from onlinepcoutlet.com. It came in a generic case with the motherboard, and processor mounted and all set to go. You might check with them, they have some very good prices on Soyo motherboards.
Chuck
