Edit/ Crap - see update....
Hi all - I picked up a Clery 800 (100mhz) for my old BH6 1.01 board. I gave it a test try setting the fsb,multiplier, and voltage but I get blue screens after Windows 98se loads.
I'm sure I need to update the BIOS as I'm still running the one that came with the board in early 1999! So I have awdflash, the SS bios, and a boot floppy ready, but awdflash has the following switches/ options:
Awdflash 7.97D (C)Award Software 2001 All Rights Reserved
Usage: AWDFLASH [FileName1] [FileName2] [/<sw>[/<sw>...]]
FileName1 : New BIOS Name For Flash Programming
FileName2 : BIOS File For Backing-up the Original BIOS
<Swtches> ?: Show Help Messages
py: Program Flash Memory
pn: No Flash Programming
sy: Backup Original BIOS To Disk File
sn: No Original BIOS Backup
Sb: Skip BootBlock programming
Wb: Always Programming BootBlock
cd: Clear DMI Data After Programming
sd: Save DMI data to file
cp: Clear PnP(ESCD) Data After Programming
cc: Clear CMOS Data After Programming
LD: Destroy CMOS Checksum And No System Halt For First Reboot
After Programming
Tiny: Occupy lesser memory
QI: Qualify flash part number with source file
E: Return to DOS When Programming is done
R: RESET System After Programming
F: Use Flash Routines in Original BIOS For Flash Programming
cks: Show update Binfile checksum cksXXXX: Compare Binfile CheckSum with XXXX
Example: AWDFLASH 6A69R000.bin /py/sn/cd/cp/cks1A26
How on earth do I know which switches to use? Help!!!!
After Programming
