Help, what memory should i get???
bauerbrazil
359
CORSAIR MEMORY 256MB PC2100 DDR RAM - OEM 32x64 184-Pin, CAS2.5-Unbuffered Requires DDR supported Motherboard - Lifetime Warranty
$64.40
CORSAIR MEMORY CM64SD256-2400C2 256MB PC2400 DDR RAM - OEM 32x64 184-Pin, CAS2 -Unbuffered Requires DDR supported Motherboard - Lifetime Warranty
$74.75
CRUCIAL MICRON 256MB 32x64 PC 2100 DDR RAM - OEM 184-Pin, CL=2.5-Unbuffered 2.5V Requires DDR supported Motherboard - Lifetime Warranty. OEM/ NOT RETAIL BOX
$54.05
256mb Mushkin PC2400 DDR SDRAM
$ 90.85
256mb Mushkin BASIC PC2100
$ 73.60
512mb Mushkin BASIC PC2100
$141.45
256MB PC2100 DDR SDRAM SPECIAL
$ 83.95
512mb PC2100 DDR SDRAM SPECIAL
$ 148.35
Im thinking to get 512MB, what memory has the best price/performance ratio? I'll get a XP 1600+ and probably overclock to 1.6GHz, so what do you guys recommend?
Thanks...
Alex
6,995
hey bauer,
id go with 2x crucial pc2100
the SPECIAL or pc2400 are only for speed entusiasts with the extra cash, its hardly noticeable performance...honest...
ow, reparei no teu nick que fala brazil...ceh brasileiro/a? tipo tbem so! heheh eh moh raridade achar membro brazuca ak! :p
