Actually, looks like maybe nitrate or phosphate deficiency. Really looks more like nitrate. Which is hard to believe given how much nitrates I have been giving them, both from a soluble fertilizer and old tank water high in nitrates!!!! But I'm all ears!
^ Unquestionably no, that does not at all look like over-fertilization. Over-fertilization looks like the whole plant drooping within 2 days. Been there, done it.
It is far more likely a nutrient deficiency, soil pH or fungus problem, and/or too much water.
Your best bet at this point is to transplant it into a larger pot or ground with good soil (soil, not some crap special bag of stuff, plain old earth dirt, lol) , not some starter "mix" and leave it alone, watering minimally until it has signs of leaves drooping from too little water. Again been there, tried and this was the best solution.
^ I didn'tseeread any indication that manure was used, nor any strong fertilizers?
Thanks mindless1 and turtile! So, the soil it is sitting directly in - i.e. that black soil with the littler perlite balls you can see, is a Kellog raised bed soil. But that is the top layer in that box. Underneatch, I have layers of compst/humis, top soil, and a bit of peat moss (I mixed these up a good, but not completely, figured it didn't have to be a perfect mix). I read that if you use straight compost it can cause nutrient burn, hence the top soil. And I read the peat moss can help with aeration.
The lighter brown stuff you see in the picture I think was just a tiny bit of some other soil (garden soil?) I had left over from some other deal so I just dumped it in. But there is such a small amount, basically what you see in the pic.
Garden certainly seems to be growing, and one or two beans have dropped, so something seems to be going well. I'll post some current pics tomorrow and you guys can let me know your thoughts! Thanks!!!
^ Again I disagree, but it is much easier than going back and forth on this, to simply pick two plants and give one of them a nitrogen salt rich fertilizer and leave the other without, and make sure not to overwater so it doesn't wash out. Nitrogen rich means truly rich at this point, around a teaspoon of 30-10-10 per sq ft may be about right, initially, then reduce to half in a week and so on till the soil is done 'sinking nitrogen.
Potting soil is usually just something like shredded bark (varies by region what waste is available) that has half decomposed, and is still sinking away nitrogen and will not be fit without supplemental nitrogen for at least a couple months of use, for fast growing plants.
I have no problems using peat. The tapwater pH offsets it as well as any minerals in the soil like calcium from eggshells. The acidity is a good thing, greatly reduces the need to use mineral salt forms of fertilizer, but of course peat is only a soil amendment, not the entirety of the soil and as such, the other soil it is mixed with provides the wicking to eventually wet it.
Soil is a recipe where all ingredients count, or where you start adding fertilizer salts if you don't have the recipe right. The right recipe mandates some use of acidic material to break down minerals into the soluble salt form, whether it happens in your soil or in the compost before transferred to its final location.
Peat composting during use is not a problem if the soil is not overwatered, so the plant roots distribute and suspend the soil rather than compacting excessively. I've had success with peat for decades, but the key (as with anything) is moderation. It's an improvement rather than replacement for other soil qualities.
