Hi All,
Basically, I had my Radeon running just fine after a lot of tweaking on my old system. It was at 190/190 with Hyper-Z turned on (via Raid-On); I was getting 3DMark scores of over 3500. My HD died so I had to reinstall all my software
I've got DX8 on the system, the same Radeon drivers and the same Via AGP except now, my Radeon crawls through 3DMark. Yes, I used Raid-On it's clocked the same and has Hyper-Z enabled. Everything, as far as I can tell) is identical to the old system except now the 3DMark runs at about 8-10 FPS on the low quality when it was 40+ FPS in the past. Also, in the low quality tests (with the trucks) the sky starts flashing, that didn't happen before. And yes, I have a fan cooling the HS for the Radeon. Like I said, as far as I can tell, everything is identical. Am I missing something?
