Salamander
I had a 2TB WD Black HD that was developing bad sectors, so I decided to replace it with a WD Velociraptor 1 TB HD. Everything seemed fine., though I didn't do a lot on the computer so I can't say for sure. Power outage the next night. Starting the next day, the computer boots up and shuts down fine, but is slow at opening up applications.
I tried to uninstall one software program, and couldn't. I get error message 1606, saying it can't access the Public Shared Pictures location on my external My Cloud device). First, the software was never installed on the external device. Then I discovered the IP address for the My Cloud device is now different from the address that appears when I try to uninstall.
I tried a system restore - it doesn't work and gives me the 0X800700b7 error message. I tried sfc/scannow as well a registry fix I found while googling for a solution. Didn't work.
I also tried unplugging the new HDD, which also did nothing.
Any ideas?
Any ideas?
