I just recently built a machine for a friend.
P4 1.6a @ 2.133 @133FSB (35 degress C)
Asus P4S333
256 pc2100
Maxtor 30GB 7200rpm
Antec SX830
Pixelview GeForce3
Windows XP
I am using the 29.42 nvidia drivers, and the card is not overclocked. I am encountering a problem in games. The games play fine for a while, then after 10,15,20 minutes, it gets real slow ,like 1 frame every 10 seconds. When this happens, but you can't really do anything. You can't press [ESC] to go to the menu, and you can't CTRL-ALT-DEL, but it isn't a lockup, it still moves, just very slow.
This occurs in Jedi Knight 2, GTA3, and Warcraft III.
Any clues?
update: i found that the problem occurs when the process called "System" (not "System Idle Process") gets locked in at 99% CPU Usage. How can I find out what the problem is?
it seems that all functions still work, they just take forever. If I am in a game and hit escape, then after about 5-10 minutes, the game finally went to the menu.
Asus P4S333
256 pc2100
Maxtor 30GB 7200rpm
Antec SX830
Pixelview GeForce3
Windows XP
Any clues?
