- May 13, 2001
- 5,715
- 1
- 0
I just purchased a watercooling kit from danger den but have run into a problem and fricken dangerden will not return my emails!
On both the Black Ice Extreme radiators and the Floppy Cube Resevoir thing, you have to screw in the plastic barbs yourself. When i tried screwing them in with some barbs i didn't need thaty only screw in half way before they get real tight and if you tighen em anymore the threads starts to get detoryed and you need to remove the barbs with a wrench. Is this how it si suppsoed to bo do you only screw in the barbs until it can't go by hand anymore? If i screw them in ALL the way (would require a wrench) they will be unuseable if ever removed. Also the floppy resavoir comes with 3 rubber o-rings that look liek they go at the end of the threads on each barb but in order for them to work you need to screw them in ALL the way. On the floppy if screwed all the way at least a quarter to half the threads will be inside the resevoir wall.
Please help me as i do not want to buy more barbs for $1 each but then pay $24 to have them overnighted to me!!!
