Help: want to do 160fsb
tran1981
862
The only thing that is in my system is gf2 and ibm 75gxp 45gig. Do you think they can stand the 40mhz pci and 160fsb?
CHHASmatroxuser
299
It depends on whether or not you have AGP x 1/2 divider, if not then I really don't think you have a chance, if you do you might be able to do it depending on MB, memory, luck etc. etc.
Wik
2,284
I have never ran into trouble running the PCI at 40. What CPU do you have that will run at that speed?
