help w/ wireless connection: DD-WRT v24/WRT54G
bigpimpatl
OK, so lately my wireless connection is ticking me off, so much that I really feel like throwing the POS around some, but anyway...
I have a WMP54G wireless card in my computer. It has been slowly dropping the connection to the router everytime i surf or download images/vids etc. I thought maybe something was wrong with the card, so I buy a new one. Also, before i bought the new card, I was running DD-WRT V23 so I upgraded to V24 RC 6.1 (the latest i think) and my Westell 6100 modem firmware was also old, so I updated that. Now, my connection is not dropping anymore, but surfing the internet is imbearable: it takes forever (1 min, 2 mins) to load simple pages like Anandtech, and streaming vids from say youtube do not work at all. The computer that is hard wired to the router seems to running OK, though i just did a speed test on it and the actual speed is half of that advertised (bellsouth 3.0 FA) so I will def monitor that.
The distance between the computer and router is about 50 feet maybe? on the same floor (basement level). There is a microwave in between but i always unplug it when not in use. I have my connection set up in bridged mode with the router handling everything. I'm pretty sure I have set up everything correctly; My connection was rock solid before this happened and I can't trace it back to any event or software/hardware change...I was also doing a traceroute one day and after going through the router, then to 65.14.248.23, then to 65.14.249.61, on the fourth line i get a request timed out, so i dont know what that is...
SO basically any help/suggestions before i absolutely annihilate my router and wireless card...:|
Maybe you have another source of interference. Try changing the channel on the wireless router. Also, what happens when you plug a computer into one of the ethernet ports on the back of the wireless router?
the computer that is hard wired to the router works fine...as for interference, maybe a neighbors N router? i hear they cause havoc on B/G wireless. I've tried channels 1, 6, and now 11...
Originally posted by: bigpimpatl
hmmm theres a bout a 25% disparity between packets sent/recieved. Would this be normal?
normally, packets received should be higher than packets sent. Check your wireless settings, but I think that you have interference problem.
I have 5 instances of Java in my add/remove programs bar..
J2SE runtime environment 5.0 Update 11
J2SE runtime environment 5.0 Update 9
Java(TM) 6 Update 2
Java(TM) 6 Update 3
Java(TM) SE runtime environment 6 Update 1
should i maybe get rid of all of em and download one update?
