Help w/ Unlocking a tbird
Schro
67
I have unlocked my 800 tbird- at least somewhat successfully-
On my A7N8X, I can only get multi's 8 and 8.5 to function for me- otherwise it results in no-postage w/ incorrect CPU setting on the next boot.
There is litterally no temp boost @ 850, or @ 864, voltage adjustments does nothing for me-
Do i need to get the pencil back out, or is there something I'm missing w/ settings
KH85
673
try unlocking with conductive paint. it is right way of doing it :D pencils can be unreliable :p
ChampionAtTufshop
2,667
make sure there is NO connection between the bridges you make with graphite
it should be :
NOT:
they should not be connected to each other in any way
