help w/ simplifying boolean expressions
RichieZ
6,551
40
I can't figure out how they went from setup 1 to 2 (6 terms to 3 terms)
click here to see it
Beattie
1,774
there is essentially... 2(ABCD) + !A + !C + !A!B!C!D
so
one ABCD cancels one !A!B!C!D leaving !A + !C + ABCD
where ! is the same as the bar.
It's been a long time since I have done this, so I am not sure if it's right
RichieZ
6,551
40
isn't this only 5 terms?
there are six terms:
!A + !C + ABCD + AB!C!D + !A!B!C!D + !A!BCD
dighn
22,820
4
i believe they used a k-map simplification. it can be done algebraicly but i dont think you'd wnt to...
basically it involves padding each term so every term has 4 variables in them. you end up with 16 terms of 4 variables then you start the factoring and stuff. kmap does it graphically
RichieZ
6,551
40
We learn Karnaugh maps next week, this is supposed to be done algebraicly
dighn
22,820
4
in that case, expand !A and !C to be full min terms by multiplying !A by (B+!B)(C+!C)(D+!D) and !C by (A+!A)(B+!B)(D+!D). even on paper that would look complicated and if i do it here using the ! notiation ti would be unreadable :p (i tried in notepad and it's a nightmare)
TuxDave
10,571
I believe it's because the C' will encompass all terms with C' in it, like: ABC'D' or A'B'C'D', the same goes with the A' encompassing all other terms. So all other terms with C' goes away. You can see this by this example:
C' + ABC'D' = (1)*C' + ABC'D' = C'(1+ABD') = C'
RichieZ
6,551
40
THANK YOU, damn I hate it when its this simple but I coudln't see it. I get the rest of it, I was just having trouble with that step
Beattie
1,774
oops, I guess I screwed up.
