<< I have 1 computer hooked up to my apartments t1 line, however I want to hook up another computer to the t1 line so we can play starcraft on line together, how do i do this? thanx >>
starcraft online together? you mean BNET? for somereason if you are "sharing" same IP address you both would be able to play on bnet at same time, but NOT be able to play together. it just wont let u join same game for some reason. but if its not on bnet and over network, then u would have no problem.
the easiest thing would be to get a router, another choice is to make ur computer gateway and conntect the other computer thru urs with a second network card.
using built in internet sharing program in win98SE or higher.
good luck.
