I'm running a PIII-700 in the MSI-6337 board (i815e). It boots just fine into Win98SE at 1.6 volts at 933Mhz. After a while (or especially in Q3Arena) the system will hang. No matter what I do (increasing voltage to 1.8) the system is just as UNstable as it was at 1.6v. This is weird to me because I've always (6 cpu's) been able to add some stability due to increased voltages to the core but not with this one. I've added heatsinks to the clock generator and chipset. I mean I can boot into Windows98SE and run for an hour at 1.6 volts (default is 1.65) but no gain in stability by increasing the voltage.
Has anyone else had issues like this? Should I be looking at things other than my CPU? I have an Alpha FC-PAL35T heatsink and the temp doesn't really change at higher voltages either.
What is this burn-in that I keep hearing and does it REALLY work?
I have a
SB-Live
Promise ATA-66
Ethernet adapter
Guillemot ProphetII-MX
30GB IBM 75Gxp ATA100 running off the onboard ATA100
Thanks in advance
I have a
SB-Live
Promise ATA-66
Ethernet adapter
Thanks in advance
