Help w/ Linksys wireless router/switch
puffpio
1,664
Whenever I have the wireless portion enabled, my laptop does not find the network, and the regular computers attached w/ cords become slow to the internet.
I have turned off WEP and UPnP to try and minimize what the prob is but I can't solve it. Any suggestions?
I have a feeling if I get it to see the wireless network, then the speed would go back up for the wired computers (ie the problems are interrelated)
ericboo
1,137
Try a firmware flash or a reset to default to see if that resolves it. Then call Linksys.
minendo
35,560
22
Is your wireless card properly configured? Is it using the correct SSID? Is it in Infrastructure mode?
puffpio
1,664
I was under that impression that w/ SSID broadcast turned on (like my router has) I shouldn't have to configure my wireless NIC especially since I have WEP turned off (as a test)
When I went to my friends house w/ my laptop it discovered the network automatically...I expected the same here.
rw120555
1,263
I assume mac address filtering is also turned off (or that your WAP is configured for your laptop's MAC address)?
puffpio
1,664
Yeah MAC filtering is also turned off. I just want to get it to work before I turn on all the security stuff
