Help w/ Geforce 2 issues please!!
Crash5427
14
OK guys..I fixed my fatal exceptions, and the only problem Im having is: When i play a 3-d game, ie Unreal tournament, tribes, etc, it goes nuts. I can see through walls, floors, cabinets, etc...everything has waves as it moves, and there are big holes in the images. I have an A7V, Elsa Geforce2, Tbird 800, 254 sticks of PC133 RAM. Using the detonator 3 drivers, but it does it w/ detonator 2 as well. PLEASE HELP!!!
Mikewarrior2
7,132
STFU Steelthorn. OR should I call you Bubba, cause that's probably who your dumb@ss is.
Crash5427, Have you at any time had hte Asus SeeThrough driver's installed? Try uninstalling your current drivers, and removing any registry traces. REboot as standard vga device.
once you reboot, reinstall det3 drivers. HOpefully that will fix your problem.
Another place that might help, http://www.geforcefaq.com
Mike
Crash5427
14
Mike..I did that:( Good suggestion though. im at work, so im gonna grab one of the comps here, take out the TNT2 card, and drop in the elsa. Im guessing if it does it on that machine as well, bad card. :(
