- Aug 24, 2005
- 2
- 0
- 0
So my motherboard broke and I needed a cheap replacement. Anyways, I fixed everything and it worked out fine. However, after I changed the Bios setting for "Auto Dectect DIMM/PCI Clk" to disabled, nothing shows on the display when I power up the computer again.
Is there any way I can reset the bios setting back to the default so at least something shows on the screen? Right now, whenever I boot up, nothing shows up on my monitor and I can't even (see or) access the bios. Any help would be very much appreciated. Thanks!
