Help w/ Dead System
lessonz
42
With all my other expenses, I really don't need this right now, but I guess that's the way life goes.
One minute computer was up, browsing the internet. I walk away turn off the monitor, and come back maybe 30 minutes later. I turn on the monitor and get a picture like normal, but my keyboard and mouse are dead, as in completely unpowered (no lights on). So, I hard booted. System boot-looped, never posting, no beep codes, nothing. Reset CMOS, no change. Yanked DIMMs of memory, moved them around, switched them out with each other (4x1gb). Interestingly, when I have less than all 4 seated, I get continuous short beeps which the manual tells me is a power error. When I reseat all 4, back to boot looping with no error codes.
I'm thinking it's a dead MB. Thoughts? Thanks in advance.
System:
Q6600
Gigabyte P45-UD3R
(I posted this on another forum, and got some advice about ensuring the CMOS was clear and playing with the RAM. I intend to try that tonight, but if there are other ideas, I'll try those too before deciding to start replacing parts. Thanks.)
Athadeus
587
Take the system out of the case and try it with just the processor, heatsink, motherboard, 1 stick of memory, video card, and power supply. Also try resetting the CMOS again with it out of the case and the one memory stick.
dfuze
11,953
I think the memory beeps are right when it's telling you power, I would try another power supply if you have a spare around.
Were you doing any overclocking of the Q6600?
dfuze
11,953
Hmm, even if the OC was a culprit, resetting the CMOS would have put that back to normal.
What do you mean by "boot loop"? Is it actually booting anywhere and then stopping, or just the board getting power, fans spin, and that's it? If it's the latter, it sounds like the symptoms I had a couple years ago with a dead motherboard.
lessonz
42
So unfortunately, I haven't been able to play with this yet, but I did borrow another PSU from a friend to try.
It's the latter. I don't even post. My first thought was motherboard, but I'm going to give the PSU a shot hopefully tonight. I'd hate for it to be the MB as replacing that right now would probably mean I'd be shelling out for a 2500k, MB, and DDR3. Doh!
MrWizzard
2,493
I have a friend that had the latter symptoms just last week. It was his power supply it was 4 years old and had done it's time.
Cr0nJ0b
1,141
29
meettomy.site
most of the suggestions above are good. If you get the new PSU in place and it still doesn't boot, I would suggest taking out the CMOS battery and remove the power cord for a while...an hour would work. I had a really strange issue that I couldn't figure out a while ago related to my ASUS motherboard not booting at all. I swapped PSU, removed the board, all cards etc...but it wasn't until i removed the CMOS battery and let all the power drain out that I figured it out. After an hour I plugged everything in and it booted up perfectly...no issues since.
lessonz
42
Okay, so I've now tried pulling the CMOS battery and flushing the caps to ensure no charge was left. The result was no change.
I also tried a buddy's old PSUs but it doesn't have enough juice as the CPU fan never gets going and the GPU lights up CTF immediately.
morbidman
77
Is your PSU still under warranty? I looked at your link and it seems to have a 3 year warranty. I know it's premature at this point to presume that it is the source of your problems but maybe it would be good to know the details just in case.
lessonz
42
This is the unit Jonny Guru cracked open, so even if it were less than 3 years old, it'd still be void. I appreciate the thought. I'm hoping to see if another buddy has a PSU I can use for testing.
lessonz
42
PSU has now been ruled out. As I doubt all 4 DIMMs or RAM have gone bad, those are ruled out, too. So, I figure GPU, CPU or MB. I've really gotta lean towards the MB at this point based on the symptoms. Please feel free to point something out I'm missing. Thanks.
