Help w/ Athlon Cooler
webart
8
I been looking to replace my SuperOrb Cooler for my athlon 1.4Gig cpu. Which currently idles at 49C. Which I think is pretty high, I want to overclock this to 1.5(Asus A7M266). However I want to lower my temp before I attempt to overclock. I want a fan that will outperform the SuperOrb (3 or more degrees, which i think is possible considering how crappy the superorb is). Can someone recommend me a fan that has
(1) Very Low Noise, i think the superorb is at 43dB
(2) outperform SuperOrb
If you guys have links to some more reviews, that would be great.
I feel like such a moron for wasting my money on the orb, Loud, crappy, and big.
Thanks in advance,
WebArt
Notes*
(1) My temp readings are from Asus Probe.
(2) I know I should read from MB Monitor but I could not get it to work.
(3) I have read many different reviews on some of the HSF out there, but I am more confused now then ever before.
Y23KC
1,517
Get a GlobalWin FOP32. I've got one of these on my duron 800@1026mhz and it idles at about 42degrees celsius. 48degrees fully loaded. Do a search on google for processor cooling reviews to see which is the best.
Y23KC
1,517
If that cooler don't keep it cool, then water cooling probably won't help! Damn, that's a huge cooler! And very quiet! You can also buy JUST a heatsink with screw holes and try these with a larger, quieter fan.
NightTrain
2,150
If you blow through a fan adapter, you can get back pressure sufficient enough to actually make it cool worse.
If you want to cool you Tbird, spend $45 on an MC-370 Swiftech. It's relatively quiet, very easy to install and an excellent cooler.
SpeedTrap
Banned
Apr 2, 2001
1,705
the zalamn 5000 out performs every heatsink you can toss at it, and even a dumbass can install it
