Help w/asrock extreme6 - Realtek ALC1150
hope this works
Sometimes you can get one to work yourself without using IMGUR etc, but it depends using copy image location etc depending if someone has it hosted but it seems to be hit and miss to me.
If you're worried about the pic staying up you do need to host it yourself, ya.
Got it guys, thanks for help.
I guess something off topic i have an asrock z97 extreme 6 and having super hard problems getting updates for asmedia chips. asrock site is old as dirt and i cant seem to dl off asmedia site does anyone know where i can find updated drivers for Asmedia ASM1042AE USB3 1.16.15.0
Asmedia ASM1061
thanks,
sebastian
Thank for you posting the STOP code. Now we can finally start debugging rather than guessing. 🙂
What you have is STOP 0x0A (IRQL_NOT_LESS_OR_EQUAL). This is usually related to malfunctioning hardware. Since it looks like your system is able to successfully save a dump, download WhoCrashed, and use it to analyze the dumps. Then post the results here.
